Prestige for sale on Gumtree
Morciii
Re: Prestige for sale on Gumtree
Nice one Dieselman. There must be plenty of xantias being broken, or in scrapys. I'll have a look and see what I can find. Cheers
The caveat is to check how many port there are out from the pressure regulator. If it's then same number, the unit should work.
If you can't find one locally, try AEP in Glasgow, who may have a used unit, alterantively phone Richard on 07766 354449, who will have one.
- jamescarruthers
At Pleiades now and he says it is £115+VAT (+surcharge on top to be refunded after you send yours back).
Telephone 01487 831239. You can have it with you by the end of the week he reckons.
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
- jamescarruthers
Oh, and he warns that you should make sure your accumulator sphere is fully charged as that is likely to wear the o-ring on the pressure regulator out again if it is flat. (Likened it to fixing a puncture but leaving the nail in the tyre)
You can work out if the accumulator sphere is roughly right by analysing the tick time of the pressure regulator. I am not sure of what the time is on an XM but someone more knowledgeable than me will let you know I'm sure.
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
Morciii
Hiya James, thanks for getting back to me. That's definitely an option.
I'm not clued up at all with the hydractive system though, so I'm not sure if I'll be able to work out if the sphere is flat or not. And by the sounds of things, my local MOT place wouldn't either.
Morciii
I've sent off a few requests to breakers for a pressure regulator off a Xantia. Hopefully I can get one, get it through an MOT, then take up James' offer, and get my old one refurbed.
- jamescarruthers
I think someone else here suggested wiping the regulator off and putting it in for a retest if the leak isn't that bad. That seems wise to me too. Then you can fix it at your leisure later.
Put the car on high and if you hear the regulator clicking on and off a lot, the accumulator is flat.
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
Morciii
The accumulator must be flat then, there is an on and off clicking sound from the engine bay after the car rises. So that'll be something else to add to the list. i think I'll need to replace all the spheres sooner rather than later then.
- jamescarruthers
The ticking is okay, it just depends upon how often it occurs!
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
Morciii
No worries. I've ordered an exhaust system + CAT, so when I go up, I'll give the regulator and good clean, and drive it round the yard, see how bad the leak actually is.
Someone breaking a Xantia got back to me. £45 delivered for a regulator.
