Breaking - XM 2.5TD VSX Estate
Re: Breaking - XM 2.5TD VSX Estate
Post by xmexclusive » Sun Aug 15, 2010 9:41 am
Hi Franklin
I will have the strut heads as they are the larger type and do not fit Pauls 2.1 unless he takes the struts as well.
Post by Duke » Sun Aug 15, 2010 10:06 am
Hi John,
Ok that's fine if Paul doesn't want them/won't fit...I will take some pictures for you and Paul so you can see the condition.
Cheers.
harryjoe
Post by harryjoe » Sun Aug 15, 2010 3:40 pm
Hi Duke.
Does the rear n/s elecky window machanisam work the same for the estate as the hatch, my cables have shot themselves round in the motor, so in need the a replacement ???
And just a quick question, !! i'm getting a loud buzzing noise coming from under the dash on passenger side when i turn the igition on , could it be a relay ? of some sort ?? , not heard it before up until today ,,
Any thoughts
Nigel
1997 Xantia 1.8i auto (sold)
1995 Clio Auto 32k mint cond
1997 Xantia Estate 1.9 td
Post by Duke » Sun Aug 15, 2010 3:59 pm
Hi Nigel,
I haven't tried the windows yet, but will see what they are like when I am with the car and report back for you.
Unfortunately I'm not sure about the noise - I'm no expert on XMs you see! :) Perhaps try the Electrical Technical section.
Cheers.
Post by Dieselman » Sun Aug 15, 2010 4:08 pm
Any thoughts
Nigel
A leaf stuck in the fan?
Post by xmexclusive » Sun Aug 15, 2010 4:18 pm
Hi Harryjoe
Stock fault is wear and a bit of conductive debris in the contacts of the indicator stalk.
Causes the indicator relay to click but does not operate any of the lights.
Clean or repair, plenty of posts about this fix.
Should give you an introduction to that boon of XM repair the "pingfuckit" as christened by Ciaran.
Easy to take to bits once you work out how to get in.
No chance of capturing all the bits that spring out.
No hope of knowing where they came from.
harryjoe
Post by harryjoe » Sun Aug 15, 2010 4:19 pm
Could be , but this is a buzzing that sounds like it could be a relay , not sure ! but i still does it when the fan is turned off,
Il'l have a look through the electrical section
Thanks
Nigel
Post by xmexclusive » Sun Aug 15, 2010 4:32 pm
Hi Nigel
Another stock fault is continuous buzzing.
Irritating but difficult to pinpoint.
This usually turns out to be the dirt and muck in the climate control sensor fan.
Found in the central roof light fixing.
Unscrew light to get at, blow out the dust and lubricate.
Post by Duke » Sun Aug 15, 2010 4:33 pm
A bit O/T from the above posts but to anybody interested, the plip and receiver for the remote central locking work brilliantly! :)
Post by xmexclusive » Sun Aug 15, 2010 4:41 pm
Hi Duke
Two plips or only one?
Condition of button rubber on plip?
Would be useful to know where car is going to be scrapped.
Thanks.
