Selling off one (or bits
Post
by Dean » Fri Jan 15, 2010 6:14 pm
now ive said that i have a niggling feeling the teves ecu is buried under the abs valve block
here is a relevant post anyway
http://www.club-xm.co.uk/forum/viewtopi ... plug#p8363
And here is what you need,
If you find you have a Teves ABS system then the ecu is below the battery tray bolted to the side of the ABS block. I've never worked on one so I cant tell you which order the pins are in on the plug. However, here are the pins and to which wheel they refer:
Pins 15 and 30 Left Hand Front
Pins 1 and 6 Right Hand Front
Pins 28 and 19 Left Hand Rear
Pins 29 and 31 Right Hand Rear"
Post
by xmexclusive » Fri Jan 15, 2010 6:38 pm
Hi Scooters
I am afraid that Teves was the ABS fitted on XM's from 1996 onwards.
I much prefer it to the earlier Bendix ABS but that is only because in my experience it has a much lower failure rate.
It is not so easy to work on but that only matters when you have to do something to it.
I note your limited time available so that a DIY repair with its steep learning curve is not practical.
It might well though be worth you getting someone with a Lexia to read and note the recorded ABS fault codes.
If the reading is successful then the faulty item(s) is likely to be identified. At the end of a reading stored faults are cleared.
This alone might bring the ABS back working for a while.
If the Lexia fails to read then the ABS may well just have lost one of its power feeds.
Fault in this case is often just a blown fuse.
Regdorpten
Post
by Regdorpten » Sun Jan 17, 2010 5:19 pm
Scooters,
i bid on this when it came up on ebay in november but didn't make reserve. I asked the seller a few questions back then but don't remember him mentioning the ABS light. has it gone on the blink recently recently?
What's the ride like?
matt
1994 S2 CT auto hatch green Exclusive, SE London.
scooters
Post
by scooters » Thu Jan 21, 2010 7:50 am
THIS CAR iS NO LONGER FOR SALE. I HAVE DECIDED TO KEEP IT.
Yup you talked me out of it. Although there are a number of niggles i have decided to keep it.
Reg....the abs fault manifested itself in my ownership i suspect the car stood for 6 weeks or so before the owner sold in that very damp autumn we had this probably didnt help.
I will have a look at the abs this weekend i suspect a fuse.
1997 XM 2.0 turbo auto VSX
1996 Volvo 850 AWD Estate
1997 Daihatsu Sportrak
1991 VW Golf Clipper Cabriolet
1972 Daf 44
1955 Morris Minor split screen series 2
Post
by robert_e_smart » Thu Jan 21, 2010 8:36 am
Good news Scooters.
I think you have made a good decision there.
Regdorpten
Post
by Regdorpten » Thu Jan 21, 2010 12:18 pm
Re ABS this might get it through the MOT: last year I took mine to a hand car wash place, and put it on the high setting while they washed the wheels. They must have dislodged some muck because the ABS light didn't bother me for another six months. It's on and off again now, though.
scooters
Post
by scooters » Sat Jan 23, 2010 10:11 am
I'll give that a shot - thanks for the tip BTW - could be the solution. MOT is in February so will be probably putting into a specialist to put it through mid beb -
either Chevronis in Leith or Citronics in Harpenden
1972 Daf 44
