Lower wing was mainly filler, very deceiving as it looked great before I removed it.
Breaking 2.5TD Manual Estate
- Kitsamus
- Orga / RP numbers: RP 6555
Re: Breaking 2.5TD Manual Estate
Current:
Citroen XM 2.1TD Exclusive 1995 (White) RP6555
Citroen DS3 1.6 Sport 2012 (White)
Previous:
Citroen C1 Urban Ride 2019 (Blue)
Citroen C6 Exclusive 2007 (Black)
Citroen Saxo 1.1 SX 1999 (Blue)
Previous:
Degens
Do you have door knobs, those inside that go over the metal pin that goes up and down; I could do with 2.
The door lock buttons from a 2.5 will be Series 2 type.
These were also available new from Ali Express, with an improved grub-screw fixing, rather thwn the original (and rather fiddly) plastic clip.
S1 cars will need the earlier type.
Degens
Ah, so this car is a series 2. That is a pity. The knobs are not available at Chevronics nor at van Gompel in the Netherlands.
Kemlo
I need a few bits, including a gear knob... I'm in Gomersal, would I be able to pop over in mine and see what you have that I can use and agree a price there and then?
I have acquired drivers side lower.. I assume the passenger side was the same. That's the only one I need now.
Thanks
Manual gear knobs were not too long ago, available from Citroen, as they fit the Berlingo.
Kemlo
- Kitsamus
Gear knob is available, will be next weekend before I'm free, PM if you want to come over next Saturday or Sunday.
What other parts do you need?
Current:
Previous:
Previous:
Passenger wing BOTTOM part from the mould downwards if its good and solid..??
